Direct link from BBCRM data to data visiualisation app and two other cool tips
I started using PowerBI in 2016 and it's amazing!  Needless to say I was so chuffed when it became apparent we could do a direct live link from CRM to PowerBI!
As I use PowerBI, the instructions for how to do it are below
Create your query.  Remember to include all the possible fields you need.  ALERT – if you forget a field and want to add it after you connect to PowerBI, you should add it to the end of your field listing, do not move it up the list.  This will confuse PowerBI and break the link.
Click on the Odata Link hyperlink.  Copy the link – this is basically a URL to the query in CRM
2be915540f61daf6f8e687bfb81003e6-huge-20
4e23778a7afa73d9b2630581bcb96b53-huge-20
Within PowerBI, click on the Home tab / Get Data/More/ Other/Odada Feed.  Highlight it and click Connect
3c95abcbcc570eac06de508f10099652-huge-20
437368ea6d4234b8c2f5ba5531892240-huge-20
Use the Basic option, paste the URL into the URL field, click OK
fe7de5c85edf08506b309b3653aca088-huge-20
You will then see the data in the PowerBI query tool, click edit to manipulate the table before loading it in the Desktop tool
26d0099fd921904e1b624277d03e3974-huge-20
Now you can use the visualisations to show your data, have fun1
Using the ouput field in Query
Who uses the output field in the query tool?  It can be very useful under certain circumstances.
You need to include the field you want to filter on within your column fields.
a66bb7ce387d066b42ab9b706a6f0afa-huge-qu
208a57e7c7d4ce9a8012be8121dc0726-huge-qu
TEMP folder in Query
A simple suggestion.  You know all those queries you create when someone asks for all the major donors in a particular state that funded the widget project?   And then the query library starts to look like a hurrican hit during the night?
Just put all those in a Temp folder, set up a reminder in your calendar to delete them once a month ?
ba6201615cc93019601f5867adb64261-huge-fo
