What's New In SKY Reporting: Scatter Plots And Bubble Charts!
To help analyze multiple measures for correlation and comparison, you can now design an insight as scatter plot or bubble chart in Analysis.
A scatter plot displays an attribute's values as points along two axes, to ease correlation and comparison of two measures. For example, in Raiser's Edge NXT, you may want to compare the expected and funded amounts of opportunities, based on their purpose. To design a scatter plot, select Scatter plot, and choose the two measures to compare and the attribute to analyze for correlation.
Similar to a scatter plot, a bubble chart displays an attribute's values along two axes, but with a third measure represented by the size of the plotted points. For example, you may want to analyze the expected vs. funded opportunity amounts above in context of the resulting giving credited to each fundraiser. To design a bubble chart, select Bubble chart, and choose the two measures to compare, the third measure for their proportional relationship, and the attribute to analyze for correlation.
When will SKY Reporting be available to everyone?0
Hey Daniel! Stay tuned, as SKY Reporting should be moving from an Early Adopter Program to a waved rollout in the coming weeks. Thanks for your patience!0
