Update Invoice LineItem Comment
Is there a way through the API to update an Invoice LineItem Comment for FE NXT?
@Scott Rogers
https://developer.sky.blackbaud.com/api#api=57a342f1d7dcde1c28a749fe&operation=EditInvoicethis should be what you looking for
@Alex Wong I saw that but did not see anything in there about editing line items of the invoice
@Alex Wong Actually, I see that there are not any API options for Receivables for FE NXT, only Payables. Doesn't look like I can update anything on a Receivables Invoice, is that correct?
@Scott Rogers
there's no account receivable api module.. though I did not check the other module if it is “buried” in GL or otherwise.@Erik Leaver may be able to more directly answer you on this.
@Scott Rogers As per the Fall Product Update briefing, APIs for Treasury & Accounts Receivable are being worked on. The Spring PUB should have an update on the timeline.
