Grading Key missing on New Grade Entry update
Teachers have pointed out that a Grading Key no longer appears in the new grade entry format. Has anyone seen if there's a way to add that back to the new format?
It does still appear in the old grade entry screen, available from the actual class page as it's own tab. If accessing grading the usual way, from the Grading tile next to attendance, only the new format is available. I assume the old format will be depreciated at some point, so advising teachers to use that is only a temporary solution.
I didn't see anything about this in the KB.
