"Cached" Query Results?
Not sure I'm using the right terminology, but what I'm wondering is if the results for a given query can be cached in some way so that once you've run it, you can revisit the other tabs in the query (Criteria, Output, Sort) and then go back to Results without it re-running the query if you didn't make any changes. DB view query does this and it's very helpful to be able to double-check what you entered on those other tabs without having to wait for a large query to run again. Web view just re-ran it.
The query I used is shown below. Hope this makes sense.
984d15c880fd9c5d086b242c51713b84-huge-im
  • @Amelia Ketzle Hi Amelia. It should be behaving as you describe. I see that it's not, it must have gotten broken at some point. We'll get that fixed. Thank you for reporting it.
