Any updates to New Email Builder?
I'm making another attempt at using the new email builder and a few things I'm running into are:
- Adjusting padding for the width of the entire email ( I can't get rid of a very wide margin). I'd like our top banner image to fill the whole width of the viewport.
- Center buttons and the option to make the button width 100%.
- There is a lot of space between images and captions. I'd like to make adjustments there.
Are there any workarounds (besides using the HTML editor)? I'd also like to know if there have been any updates recently that I'm missing.
No updates that I am aware of, but the padding issue that you are seeing can probably be fixed by adjusting your stationery. We essentially don't have anything in the stationery anymore and utilize reusables to build out other components of the e-mail where the drag and drop email is lacking.
@Gwendolyn Chambers, it's possible to center buttons by placing them in a separate column with the style for that column set to center rather than left-aligned. You can even put text blocks in that same column, but any text you do not want centered you need to manually adjust the alignment on in the text editor.
