Student Parent Directory - Separating Campuses or Multi-selecting grade levels
Hello,
Was there any easy way to separate campuses or multi-select grade levels in the built-in directories under Reports?
For example, we have a K-12 school and I'd like to create separate directories for elementary, middle and high.
There's an option to filter by grade level, but this only lets you select one grade level. The workaround I've been doing is selecting the option to sort by grade, but I have to go into the PDF and edit it manually to separate it into three directories.
  • @Nathan Ong:
    Hello,
    Nope. This is an idea that's been in the idea bank for nine years, and crickets from Blackbaud.
  • @Brian LeBlanc Oh that's unfortunate to hear. I hope they seriously look into some of the more upvoted suggestions
  • Jessi Walters 2
    Jessi Walters 2 Blackbaud Employee
    Sixth Anniversary Facilitator 2 Name Dropper Photogenic
    @Nathan Ong Check out my questions in the Idea that Brian shared; I'm looking for input. Thanks!
