Survey API
Does anyone have a working example of the survey API? We're having difficulty getting it to work properly and a live example would be very helpful. Thanks!
Hi Amy,
Let me see if I can get anyone to respond. If you're having trouble, you can open a Support case and get some help it. It's not something our Level 2 Support handles so it may take a little while to escalate it to the right person. Another option is to contact your CSM. They may be able to escalate this and get you help quicker.
Kent
Amy,
luminateExtend.js, a JavaScript library I created for use with the Luminate Online API, includes an example of a simple sign up form using the Survey API. Check out https://github.com/noahcooper/luminateExtend/tree/master/examples.
Noah Cooper:
Amy,
Awesome - thank you so much Noah I will check it out.
