Prospect Ratings Import
HAPPY NEW YEAR! Does anyone have an Import Template that they would be willing to share for importing Prospect Research information into the Ratings Category of the Prospect Tab?
Thanks so much for your consideration. ?
@Shelley Bell We use DonorSearch ratings. Here are the column headings and sample ratings with constituent ID used for the import:
ConsID PRateDesc PRateCat PRateDate PRateSource PrRate_Notes 417006 DS1-5 DS Rating 8/30/2021 DonorSearch The “DonorSearch” philanthropic and/or wealth ranking of a prospect’s ability to make a major gift PRateDesc is the actual ratings
PRateCat is the category or rating name.Notes are necessary but help for those who don't understand the rating types.
WE have 8 different categories of ratings that we import. I add them in the same order each time I import so that when I do exports, the rating categories are in their own columns. You can get around this by adding a rating name to the Source so you can export specific ratings just by using the Source as the filter.1 -
@Mark Guncheon - this is perfect. Thanks so much. We are actually adding DonorSearch info, so this is spot on. I wasn't sure if I needed an Import ID for Ratings?
@Shelley Bell One will be created for you by Blackbaud during the import process.
@Shelley Bell And I forgot to mention…as with any import, test it before importing.
@Mark Guncheon - Also, just curious which 8 DonorSearch categories do you import? Thanks.
Rating Quality Score Major Gift Likelihood Annual Fund Likelihood Wealth-based Capacity PGID RFM Total Estimated Capacity 1 -
@Mark Guncheon I created a layout in DS that puts these ratings in this order.
