If record has already been imported, is there anyway to change the import id?
Once a constituent record is imported in the system, is there anyway change the import id? ? In other words, I want to change the import id of old existing constituent records. Because I don’t want the import id to be a random number that are generated by the system (e.g 00000-000-000000000), I want it to be a specific number that I want to specify (e.g donor number: 12345). The records I want import were supposed to be donor numbers, but instead the record import id was not specified and the system assigned a random number.
@Chris Li
you cannot change import id once it is created. Import ID can be specified at the time of creating new constituent only.For a constituent record, there are essentially 3 IDs:
- Constituent System Record ID
- cannot be specified at creation time
- cannot be changed
- can only be queried
- Constituent Import ID
- can be specified at creation time via RE database view native constituent import
- cannot be changed afterward
- can be queried on, can be used in future import to identify existing record
- Constituent ID
- can be changed afterward (if business rule did not forbid it)
I don't know why you need constituent import id to be the way you want it, you have Constituent ID for that purpose.
8 - Constituent System Record ID
I can't agree more to @Alex Wong's post. I don't know if there is a need for this, as it can be exported out if necessary. With Constituent ID being able to be a user defined and changeable ID field, I don't know if it makes sense to be edited after creation.
4 -
@Chris Li Did you put the number as the Constituent ID or in the field for the SSN instead?
@Christine Robertson No, I haven't put the number into those fields. How would that help?
@Chris Li You can't change Import IDs, but those two fields can also be used to identify records when importing. The SSN field is a bit tricky though as it has encryption functionality to protect actual SSNs. So, if you have a specific donor number that you want to use on existing records, one of those fields might be an option.
@Chris Li
Everything you do in RE goes back to what you are trying to achieve as a business/org.Is there any particular reason why you are fixated on constituent import id? I do not suggest using SSN field for anything other than SSN. If you want to define “an ID” that conforms to your naming convention, use Constituent ID.
3
