How to apply the page wrapper to the participant center
When i click through from my team raiser to the participant center, the wrapper does not carry with the page and it's a white generic page with the standard log in.  how do i apply the wrapper to the participant center?
  • Create a custom page and put [[S409]] for the content.
    This puts the PC into an iframe on your new custom page.
  • Brian,
    Then what?  I have a Custom Page with the Participant page code.  How do I render it for Participants?  I'm missing something here.
    Jeff
  • Hi Jeff,
    After that, you will have to edit the Participant Center to use that page as the "home" page. Follow this path:
    Fundraising > TeamRaiser > Participant Center (tab) > Edit > 2. Configure Options > 1. Participant Center Home Page > enter the URL for the custom page or use the select button to locate it
    or if you only want to do it for a single TeamRaiser.. you can override the main PC settings in a TeamRiaser via this path:
    TeamRaiser > Edit > 3. Select Event Options > Edit Advanced Options (under Related Actions in lower left) > d. Confiure Participant Center Override Options > check the box in #2.. then enter the link to the custom page in #3 or use the select button to locate it
    Jon
    Jon Reich
    Cathexis Partners
    www.cathexispartners.com
