Assigned Appeals
Hi all, I'm pretty sure I know the answer to this question, but hoping I'm wrong…Is there a way to mass delete an appeal from a bunch of constit records? I just imported appeals onto 1800 records only to discover that the import file I was given was screwy and folks appeared multiple times and with multiple packages. I'm pretty sure the answer is no, but maybe not?!?!?
@shani traum - Hi Shani, global delete works well in this situation. You can probably use the same query you used to add the appeals to do the delete. If you have never done a global delete, let me know and I can share my procedure doc with you. I do this all the time, but always have the procedure open and in front of me to make sure I do it correctly.
5 -
@Dina Rieman Ooh, yes please! And thank you!!
@shani traum you're welcome… I messaged you so we can connect.
