Is there a stag similar to S57 for donation levels?
I only want to show the "choose your fund" dropdown, not the premium. Is there a stag similar to S57 that will only show the fund options?
Hi Shannon,
I am afraid there might be no S-tag to render the donation level as dropdown automatically, but you could achieve that through Javascript coding to manipulate / convert the radio buttons to <option> value of a <select> HTML dropdown
Other alternative would be to entirely recreate the public facing form and map and perform the donation via the donate API and/or startDonation API (if you also want to use the Paypal)
http://open.convio.com/api/#donation_api.donate_method.html
http://open.convio.com/api/#donation_api.startDonation_method.html
Daniel Hartanto:
Hi Shannon,
I believe I will need to use the getDesignees from the API, although I'm having trouble getting anything to display. I also don't see anywhere in the API documentation on how to call the API on a pagebuilder page, since I won't be outside of the site the cross domain js or jquery examples don't help. Do you know the code that I need to put into the pagebuilder page to call getDesignees?
Shannon Walston:
We ended up using the API solution here: http://community.convio.com/t5/APIs/getDesignees/m-p/84412#M1720
