Crystal Report, sub reports set to Suppress when report run out of RE
Hello All… has anyone had an issue with Crystal Reports 2020 setting sub reports to suppress when running the report through RE? They run perfectly in the CR developer.
Using Database View of RE NXT; exporting Access2000 files; report built in CR 2020
Thx
@Jennifer Lovelock You probably need to use the "Blackbaud Report Writer Database (MDB)" instead of Access 2000.
@Joshua Bekerman bCLO bCRE… I was really hoping that this solution would work, but unfortunately the sub reports are being set to suppress at run time, and I have to reset them in Crystal Reports.
Have you heard of anyone successfully running reports that contain sub reports that were created in Crystal Reports 2020?
Thx
