Add survey responses to survey autoresponder
Is there any way to insert a participant's survey responses in the autoresponder email they get after submitting that survey? We get a lot of requests for this.
Somewhat.
If you go into Settings > Database Config > Additional Information, you can enable create custom fields that capture into a user record. There's an upper limit on how many fields you can create, so this will only take you so far.
And in surveys, you can have an answer update a constituent record field that matches. So you could:
- Make a custom_boolean2 called “Likes Peanuts.”
- Add a True/False question to your survey, “Do you like peanuts?”
- Set the question it to update the record.
- Put [[S1:custom_boolean2]] in your autoresponder, or use it in a conditional to render a phrase.
