Rejoining Multiple Constituents
I have accidentally dropped a large number of constituents' memberships. I have run a Membership query which identifies all those affected. Is there a way I can use that query to Rejoin multiple Constituents - there are too many to do this manually via the Constituent Record → Rejoin.
Nigel, I recommend re-joining these donors through the Global Add - Memberships function under your Admin tab. This works well as long as you are fine with having all identical start and end dates on your membership intervals.
