Luminate Open API IP Range for Whitelisting
Just getting started with Luminate's API and our dev team is asking… We need Blackbaud's IP range in order to whitelist it within the data environment we'll be connecting via API. Is this documented somewhere?
Hi Katie, and welcome to Luminate Online. You do not need to add a Blackbaud IP address in Luminate Site Options for Open API Configuration. If you plan to use LO API Server API calls, then you do need to add the IP address of your server working with the server calls. If you only plan to use Client calls, you don't need to add an IP address.
