Two OLX forms - would like to combine
Hi - I have an event with a morning and evening session, with capacity limits for both. I've set up 2 separate registration forms, but would like to display them on the same web page. However, both have the div id="bbox-root" and I need these to be unique. Can that be changed? How?
  • Austen Brown
    Austen Brown ✭✭✭✭✭
    Hi Megan - OLX Forms do not play well when listed together on the same webpage. You could make a landing page of sorts that explain the event and has two buttons that link to each of the forms on a separate page.
    Check out the OLX Idea Bank and see if this topic is listed.
  • Yes that's what we did. Thanks.
  • I have a memory of bumping up against this at a former job and in our Wordpress platform, it was possible to add a second box to the page and put the form separately into each box. But this was a while ago, so I couldn't tell you for sure if that would still be possible. Glad you already found a way that suits you!
