Adding Multiple Gift Adjustments At Once
Does anyone have experience with adding multiple gift adjustments in RE at the same time? Is there a way to accomplish this?
  • Austen Brown
    Austen Brown ✭✭✭✭✭
    Hi Brooklyn - There is no way to add gift adjustments in bulk, they need to be added one-at-a-time. However, if you utilize a query and keyboard shortcuts, it can speed up the process.
    Alternatively, if you are not tied to using gift adjustments, you can un-post the gifts using a plug-in and change them through an Export/Import or Global Change. If you go this route, please note that the un-post plugin should be handled with caution, triple-check that you have loaded a gift query into it prior to starting the un-posting; if there is no query loaded and you click start, it will un-post all the gifts in your entire database.
