Changing the order of eCard selections/thumbnails on donation form
When including multiple eCard options on a donation form, the order that they appear seems to be set in the order of date that the eCards were created.
Is there any way to change the order that the eCard selections appear?
  • Hi, Laura!
    After some testing it appears, at least in our instance, that eCards are displayed based on the name of the eCard. With this type of sorting you could utilize a numbered system (01, 02, 03, 04, etc) at the beginning of the eCard name to set the order on the donation form. If eCards are shared across different donation forms AND the order is expected to be different for each you might need multiple copies of the same eCard if you go with this strategy. Otherwise, it should work pretty well.
    Richard
  • Thank you, Richard!
    Aha, the order is indeed alphabetic by eCard name. The numbering system does the trick, and yes, we may need to make copies with different numbering for alternate forms.
    Much appreciated,
    Laura
