Operator "one of" Vs using AND
Morning all,
I have built a query which tries to find records which have 2 specfic solicit codes.
Initially i built the query using Solcit code description = X AND solicit Code = Y
I thought this would show me every record which had both solcit code X and Y. But the query came up blank.
I then created a query using Solicit code one of X & Y and ticked the box for "Each record must meet all specified criteria" and this worked and returned the records I was expecting to see.
In my mind, the two scenarios are doing the same thing but that obcvisouly isn;t correct! Could anyone provide any insight on why the 1st way using the AND function didn;t work?
Cheers
Dan
  • Thanks for your help Alan
  • Thanks Lynnette
  • You if are looking for both solicit codes have to be on the records that come up then it should be AND.
    If you are looking for either X or Y solicit code to be on each record that comes up then it should be OR or ONE OF... Solicit Code = X OR Solicit Code =Y. or Solicit Code ONE OF... X new tline Y
  • Hello Dan,
    Yep! Like you, sometimes I got trapped thinking the whole picture, rather than thinking linearly like a computer which is one record at a time. What I mean is that the query is actually not checking all the codes at the same time; but it is testing one code at a time. So your query condition needs to reflect the same way.
    Say, a constituent has 3 solicit codes (namely, Z, Y, X)...
    Your Scenario #1:
    Does the 1st solicit code (Z in this case) satisfy the Query Condition of "SOLICIT_CODE=X AND SOLICIT_CODE=Y" ? Obviously "No".
    Does the 2nd solicit code (Y in this case) satisfy the Query Condition of "SOLICIT_CODE=X AND SOLICIT_CODE=Y" ? Well, since we know you can't be X and Y at the same time, so "No" - it dose not meet the criteria.
    Does the 3rd solicit code (X in this case) satisfy the Query Condition of "SOLICIT_CODE=X AND SOLICIT_CODE=Y" ? Same thing "No" like above.
    = > The query result comes up empty.
    Your Scenario #2:
    Does the 1st solicit code (Z) satisfy the Query Condition of "SOLICIT_CODE IS ONE OF (X, Y)" ? Obviously "No".
    Does the 2nd solicit code (Y) satisfy the Query Condition of "SOLICIT_CODE IS ONE OF (X, Y)" ? "Yes"! This solicit code meets the criteria.
    Does the 3rd solicit code (X) satisfy the Query Condition of "SOLICIT_CODE IS ONE OF (X, Y)" ? Same thing "Yes" like above.
    = > The query pulls this constituent in the result!
    Hope this quick illustration helps!
