Splitting couples into separate constituents
I have a new Director of Advancement and this is the time to shake things up from how it's been done for longer than I've been here (12 years now). Now that we have the Events module, I'm trying to transition things there (instead of tracking everything as an action....such a headache), but I find that I have to manually add the non-constituent spouses as guests in order to have correct participation numbers. That's taking more work than the old way, and since all contact info - primary and spouse - is on the main record (another thing I hate), I can't pull an easy email list in RE NXT for all participants. Unless I'm missing something? If I am, please let me know.
I'm going to be lobbying my Director to go to make spouses into their own constituents. Is there any way to do this other than manually going into all records and splitting out the spouses? If not, this is going to be a summer project because I'll have over 700 records to split (and that's if we only do parents). I have already worked out a way to deal with gift entry, addressee/salutations, and HOH/mailing lists; I'm sure it'll need tweaking as I roll it all out. This will be a big undertaking but once it's done, we should be good to go.
Thank you all in advance!
Hi Robert Brown,
This will not be the answer you are looking for - just a quick thought since this may end up being a summer project for you.
What if you split 5 or so of your active constituents now until you get to the project and see if splitting the records really benefits your organization's efficiency or not.
I say this because at one point I thought splitting the records would make my life easier (didn't have event module at the time - I do now but no events to speak of at the moment). It didn't, for my organization, it turned out to be less efficient.
I'm looking forward to seeing how others answer your actual question.4 -
Like Elizabeth Johnson this may not be the answer you're looking for.
While I don't have much experience yet with the Event module I could connect you with our team member who works with it. She may have ideas on adding non-constit spouses and I know she has dealt with issues with participant #s. I know she does a lot of work from the db side as NXT still is missing many functions. Hopefully someone here on the forums has suggestions.
I was going to suggest splitting a small number of records as needed, maybe for a specific Event/project. (When splitting, deal with soft credits at the same time.) See what your other implications are. Having switched orgs after 10 years in one where I set up the db to another org, I find that not everything works the same or as well in a different setting.2 -
Hi Elizabeth and JoAnn,
There are other reasons why I want to do this, including finally connecting our database to our website - hosted by Blackbaud, I forget the name of it now but it used to be the onSuite I think? - so I don't have to enter information changes manually. As far as I know, we have to split up the records to have the connection happen. Also, I'm getting tired of being yelled at by co-workers when they search on NXT for a spouse and see no contact information because it's all on the main record and they can't be bothered to make a few more clicks to get to the main record.
Your suggestions are good though, and I would welcome being connected to anyone who could help me. Thank you both again!1 -
I have worked for 3 organizations over the past 17 years and we have always given coupled their own records. One very big reason is that we need to be able to research them as individuals. They are different people - they have different associations with other organizations. They can have different sources of wealth. Raiser's Edge is made so that them having separate records works really well.3
Was talking to person who works with events, she confirmed they do not have to have their own record but there are some tricks to getting correct participant counts/lists. Send me a private message with your contact info and I can ask Sarah to reach out to you.
To get to non-constit in NXT just click 'search relationship records' at the bottom of the search list. Not that hard, IMO. You don't have to go to main record unless you didn't enter any contact info on the relationship record.
We house our couples on the same record. I guess I don't see the benefit of them having separate records. I can't wait to see more opinions on this topic. It may help me with our database.1
Hi Elizabeth! What was your reasoning to split them up in prior years? I have never even thought about splitting them up. I think it would cause more confusion but maybe I am just not diverse in this enough.0
Hi Candy Sangster! Happy New Year. We were synchronized (never a true integration) with Blackbaud's Education Edge and at that point, Education Edge had lost the option to keep the couples together. I was all for splitting the records at first and then one nightmare after the next in the end user's management of the records. So glad I did it with a test subset to start.2
Happy New Year to you also!1
I am not sure if this needs to be done. Getting the events module to give you accurate numbers can be tricky for sure, but I don't know if this will not create more problems elsewhere. I think it might be a good idea to try it with a test group like Elizabeth Johnson suggested. Generally, I'm not a big fan of creating records for spouses unless they are a donor.
When you do these events, are you not allowing attendees to have a guest? I think there's a better way to deal with attendees than to decouple them. I urge you to consider the ramifications of this elsewhere in your database.1 -
How does your organization determine if just one of the couple is a donor?0
Not sure which way you're going with your question Candy Sangster. Which is a donor or if gift is from only one of the names on the account?
If gifts consistently come from one of the couple, that is the person who would have a record. That does not necessarily mean that only the one is a donor when it's a shared bank account. It just means gifts are entered on the one record. Your addressee/salutations for receipts, thank you's and any correspondence can have both names.
If you receive checks from both spouses from the same account, it would be up to your orgs practices if each have their own record. Some orgs do, some don't.
Many of our online gifts come in with both names, (Joe and Sue) entered in the first name field. I look at who cardholder name and they are my "donor" but gift acknowledgement/receipt would have both names.
If you're asking how to know if gift if from both spouses or just one, there's really not a way to tell by looking at a check. We've always used joint addressees/salutations whenever spouse has relationship and never had a problem.1 -
I think there is a lot more to splitting couples than "who made the gift".
I've almost always worked in organizations that split records when necessary. And each had their own set of guidelines on when it was necessary. Databases have ranged from 60,000 to 600,000 constituents. Pretty much all records started off as combined, but the non-constituent spouse was often split off if: they pass and a tribute record is needed, they begin to have their own separate relationship with the organization such as a board or committee membership, event related reasons (more on that in a second), email systems that will send only to constituents (such as OLX), website integrations where it is helpful for each user to have an account (BBNC and the "On" suite which was alluded to in the original post).
One of the organizations I worked at had a very male-centric record setup. The man was always the primary record holder and his spouse was a non-constituent. Yet they held many events over a single year that were for women only. There was an inordinate amount of time spent constructing queries and mailing lists to the spouse only, and to adding the husband the event record with their wife as a "guest" but then trying to run accurate event lists. I calculated at one point and they were doing something like three times the amount of work in all of these workarounds.
I've never, in any of these organizations, had issues with reporting involving soft credits. Spouses would always automatically get soft credit for each other's gift unless we knew / understood otherwise. They were always recognized as a couple. I never heard complaints, or they were so few that I don't even remember them now.
So I think you can all see where I stand on this. ? I know there are often good reasons for NOT splitting spouses. But once you start building in a lot of extra steps because there is a refusal to split spouse records, you really need to examine the situation. It isn't always worth your time to jump through all of the hoops.
Karen2 -
Karen Diener - you're well thought out answer is perfect! Organizations often spend so much time jumping through hoops for no good reason. We automatically soft credit spouses for all gifts unless we hear otherwise and there is absolutely no problem with reporting.3
Karen Diener:
KarenKaren Diener I can't agree with this statement more. I added emphasis to your statement, because I really think the key part is determining when you need to create a constituent record for the spouse. And honestly, I think it's great to have a guideline when this is done. I also believe that we as the database managers and admins will develop a sense about when this needs to happen. Each constituent base is different, and I think it's hard to say definitively as a general rule. In this example, the issue is getting an accurate count for an event using the event module. Iff the spouse is only coming in as a guest of the main constituent, then I don't think that is really enough of a reason to create a new record. There still hasn't been anything done that separates one spouse from the other. Both are attending the event. They are still of the same household. I don't know if I see the point just to be able to get an accurate count, primarily because I don't believe they came into your database organically. I hope I don't have to define what I mean by that. But, like Karen stated earlier, I think you'll know if creating a spousal record is worth the time and effort or not.
3 -
I''m an advocate for separate records. And over time it has proven to be easier to manage in my experience. Some key things. You MUST decide and document a policy on which record gifts go on. The spouses are auto-soft credited, They all get the same formatting for Add/Sals (so that's a whole housekeeping project). If the spouses have different last names I highly suggest adding Aiiases with the spouse's last name on the other spouse's record (makes searching more finite and accurate)
With the way all of the other tools are designed within RE or not having separate records makes sense. Email tools/software that pulls directly from RE expect that the spouses have separate records. Events module is beyond sticky and impossible to manage or utilize unless the spouses have their own record.
Reporting is not an issue because you just pull on HoH and you have HoH and gift entry policies in place.2 -
The upsides of splitting records are pretty clear to me and our team (Event and volunteer management, wealth screening, email flexibility etc.). But I have a hard time picturing how to begin splitting 6,000+ household records. There apparently was a plugin for time, something called "NonConstituent Promotion Update", though I understand it's discontinued. Any thoughts?
I can see doing some type of large scale export and global delete scheme, but then how to soft credit years of giving, establish good address sharing and relationships? As a K-12 we depend heavily on parent and sibling relationships, multi-generational even.
Thanks very much!0 -
Previously (on a different system - Ellucian's Advance), we had spouses with their own separate records. This allowed us to track the spouse as an individual, which as someone pointed out, is greatly beneficial since, in the real world, they are their own person. Many things we may be interested in tracking are relevant only to the spouse and not to the “primary” record, and it is confusing to put that information on the wrong record. Especially since, in RE, there is often no place to track source codes or comments related to a piece of information (in order to record that it pertains to the spouse instead).
A few years ago, we had a new ED of Adv. Svcs. join us, and he felt strongly that we should not have separate records for spouses. When we decided to convert from Advance to BB's RENXT, we took that opportunity to convert spouses as non-constituent relationship records instead of full constit records. The main argument for doing this was that it would allow us to total household giving much more simply, without having to worry about exporting giving for both spouses and then summing it. As it happens, this did not hold up consistently, b/c we then decided that payroll deduction gifts needed to be hard-credited to the spouse whose check they were coming out of (making an exception to our own rule of hard-crediting only the HOH for gifts). So we still have to make sure to look at both spouses' giving if we want to be sure we have an accurate hard credit household total.
Also, the conversion was not nearly as clean as we hoped. I'm guessing no one on this thread is likely to be considering that as an approach, but just know that there were a lot of associated cleanups and snarls in converting them from constituents to non-constituents. I have no idea how you'd best go about promoting existing non-constituents en masse.
Our fundraisers were not happy with this change. As mentioned, many pieces of info which pertain to the spouse are now on the HOH record, which is often confusing and sometimes not labeled well (or at all). This can cause fundraisers to think Actions occured with the HOH when they actually happened with the spouse. The same can happen with Notes which were added to the spouse. If not clearly labeled, it can be very confusing what applies to which spouse. And when you go to separate info for whatever reason (divorce, death, etc.), it's often hard to tell which cell phones or emails belong to who.
Personally, I think separate records were easier, but getting there might not be worth the trouble. Also, it's a mixed bag, and my view may be a bit myopic from a data management and end-user standpoint. Not sure what's best for all the types of reporting needed in a fundraising database.
