Updating Multiple Constituent Records
Hello all! I'm new to RE and had a question about updating constituent records. What is the best (and most efficient) way to update a large group of records? Is this something batch can do or is there another way? One update I am seeking to make is to add an attribute to a number of records to indicate their current year giving society level. What is the best way to do this?
Thanks! ☺
Thanks! ☺
Your best method would be to import the information. If you have a query that can isolate your population you can then build an attribute import. below is the knowledgebase article on creating the import file. https://kb.blackbaud.com/articles/Article/50129?_ga=2.144272822.2047395330.1581629166-406802487.15584412223
As Derek said, if you can group the records into a constituent query one option for adding a constituent attribute is Administration > Global Add. Not all fields are options in Global Add, but if I needed to add one that was there, I found that to be a bit easier than import.
There are also some updates that can be done through Global Change.5 -
Thank you both for your help!!0
