How do I add people from one group to another group?
One method that can be used for adding members of one group to another group is called group assignment upload.
***To get the csv file of the first group that you are wanting to add to the second group:
1) Go to Mailmerge under Constiuent360
2) Click "Create a New Mail-Merge".
3) Enter mailmerge name, author, decription, security category (can leave this General)
4) From the list on the left, select Email/Email, click add selected
5) Click Next step button.
6) Select the Groups from the filetree, Click confirm.
7) View the status of the Mail-Merge, which should be "queued" or "in process."
8) Click on Refresh at the bottom of the table next to the Done button.
9) Mail-Merge file is complete when status reads "Generated."
10)Click on blue floppy-disk icon to download as a csv file.
***To modify the csv file from mailmerge to get it ready for group upload:
1)Change the csv file so that there are two columns:
2)Change the Email/Email to PRIMARY_EMAIL
3)Add a column called EXT_GROUP_ID
4)Populate the EXT_GROUP_ID column with the group ID of the group to which you want to add these people
5) Save as a csv file
***Follow these steps for uploading files that specify Convio Group IDs:
1) Go Import/Export
2) Select the operation: Group Assignment Upload
3) Upload the CSV file with the upload data
4) Click confirm to run this operation
5) Click on the Refresh button. (Some operations might take a couple of minutes to complete execution.)
6) Click on the operation name in the Data Sync Log to view the summary of results.
7) If = + then he operation was SUCCESSFUL.
8) Else, go back to the Data Sync Log and click on Download available to download a detailed error report.
Go to the group where the contacts were uploaded to verify that you see the added contacts
