How do I edit a PageWrapper?
All wrappers except the Active wrapper can be edited. To edit the current wrapper, you must make a Copy of your active wrapper, edit the copy, and then publish the copy.
Edit a pagewrapper as follows:
1. On the PageWrapper List screen, choose the Edit link in the Actions column beside the Name of your PageWrapper to reopen the screens where you created the wrapper.
2. Proceed through the screens in order making changes as needed, or use the Steps menu at the left of your screen to go directly to the screen where you wish to make a change.
Important: You must click the Next button on any page where you make a change to save the modifications on that page.
NOTE: This solution is only valid if you have PageWrapper Editor enabled. If you do not, you will need to contact your account manager for this information.
