Our entry page has no link to "get started"
Thanks for your help!
Kim
I'm going to change that question -- I went to Customize Pages/Configure Greeting and removed that text. Now, looking further down that configuration page, there is content for the various buttons. But it's clear none of them are active. Where do I go to select which buttons are to be active? The only one I want is "Register as an Individual."
Kim0 -
Kim Ethridge:
Kim
If you edit the TeamRaiser and look at step 16, is the event set to accept registrations? First thought is that those buttons should be missing if registration isn't available.
Jeremy Reynolds:
Kim Ethridge:
Kim
If you edit the TeamRaiser and look at step 16, is the event set to accept registrations? First thought is that those buttons should be missing if registration isn't available.0 -
Kim Ethridge:
Jeremy Reynolds:
Kim Ethridge:
Kim
If you edit the TeamRaiser and look at step 16, is the event set to accept registrations? First thought is that those buttons should be missing if registration isn't available.Have you looked at the code for the Page Builder that relates to the section of your page? The link may be missing from there.
