Multiple thermometers on one page?
Hello-
Is there a way to put multiple thermometers on one page? I have a chapter that is having a contest for their different walk events and they want to be able to display the three different TeamRaiser walk event thermometers side by side.
Monica-
  • Hi Monica,
    If you look in the Stag documentation (http://community.customer.convio.com/docs/DOC-1408), you will find various tags that you can use to show the TeamRaiser thermometer. For example, inserting the S35 tags creates either a campaign, team, or participant thermometer depending on the parameters you select. You can have as many thermometers as needed.
    I hope this helps.
    Cheers,
    Joanna
  • Hi Joanna,
    I did try to add thermometers on one page using S-Tags but I've run into an issue. I want to show thermometers for TeamRaiser events that are part of the same campaign. For example Our Colorado chapter has three different cities that are having Walks under the same campaign, but they want to display their individual thermometers side by side. I was advised that I could use the S-337 Tag, but when I put those in, it only displays the amount of people that have registered and the amount of money donated is 0.00. Any ideas?
    Monica-
  • monica.pirlot :
    Hi Joanna,
    Monica-
    Monica -
    From what you've said, your S-Tags may not be working properly. The best thing to do now is to submit a support ticket so we can determine what is not working.
    John
