Styling Custom Parts
I am wondering if anyone else who has created a custom part for their BBNC site has had any issues with styling those parts.
The part in question contains a table with cells populated from RE, but the containing div has an id populated by BBNC, which will change based on its position on the page. For example I placed a custom part on the page by itself and when I inspected it, the id was PC13040_ctl00_EventListingDiv. This is fine when styling the part to be on a very specific page; however, when I try and add the part to another page, I am going to have to re-write all of the styling again, which really goes against my Don't Repeat Yourself (DRY) mantra that I code by.
I feel like the easiest solution would be to place place a static class on the outermost container, but unfortunately, I don't have access to the source code. I could inject with with javascript, but we are afraid that tampering with that source code would void any support clause we have.
Does anyone have a good solution to this quandry?
Thank you,
Scott
Hopefully this gives you the solution I think you are looking for.
If the code on the page is something like <div id="PC13040_ctl00_EventListingDiv">thing you want styled</div> then you can call it in a style sheet by using the not unique part of the ID. Your stylesheet would use div[id$="_EventListingDiv"] { } instead of #C13040_ctl00_EventListingDiv { }
In jquery the format is $("element[id$='partial']) and in CSS the format is element[id$=partial] { }
Scott Salhanick:
Hello,
Thank you,
ScottHi Scott,
You can style the part based on the attribute selector. So in your case you can target your specific div with Selector (div), Attribute (id), contains (*) :
https://www.w3schools.com/css/css_attribute_selectors.asp
I.E.
div[id*="EventListingDiv"] { color:red;}
Hope This Helps,
Ryan
