Field Auto fill
Ta!
Victoria Kingstone:
I've recently added a number of appeals and whereas before if in a batch you started typing the appeal description it would autofill with the full description, this now doesn't happen. As soon as you open the search box, it is the only appeal listed so I know it's not that several appeals have too similar a title. Does anyone know how to get RE to autofill again as it saves a considerable amount of time on large batches using multiple appeals.
Ta!What version of RE are you running. We're on 7.93 and it works fine here.
Is it possible you changed your user options for appeals from ID to Description or vice versa? If so - I think it may be auto-looking up the wrong field... maybe.0
Victoria Kingstone:
Ta!1 -
John Heizer:
Victoria Kingstone:
Ta!What version of RE are you running. We're on 7.93 and it works fine here.Yes, we're on 7.93 too
Christine Cooke:
Victoria Kingstone:
Ta!No I didn't make it a default as we have a dozen or so appeals linked to a fund code. Thanks
Melissa Graves:
Is it possible you changed your user options for appeals from ID to Description or vice versa? If so - I think it may be auto-looking up the wrong field... maybe.I don't think so but I will go check just in case I was having a dozy moment!
Did you ever figure this out? I'm having the same issue.
