Emojis in subject lines and/or email body?
Has anyone ever successfully used an emoji in a subject line and/or email body?
I'm trying to insert a soccer ball emoji (⚽) into an email's subject line, but all of the tests are simply displaying that HTML decimal code and not the actual emoji.
Thoughts?
Thoughts?
Hi Sarah,
Check out this post. It is a bit older but should still do the job.
https://community.blackbaud.com/forums/viewtopic/1/443?post_id=49941#p49941
Phil2 -
Phil! You're the best! That totally worked! (I couldn't find that old post since I specifically searched for "emoji", and hilariously that post doesn't mention that word once).
Thanks again!Philip Nawrocki:
Hi Sarah,
Phil
That would be too easy right?!?!
(obligatory emoji)
Thank you so much for this link! I was trying to find anything on this topic by searching "emoji" but I was limiting it to BBNC only since I'm not a Luminate user. Much appreciated.
SuzannePhilip Nawrocki:
Hi Sarah,
Phil
How about specifically in an email body? The workaround from the older thread works in subject lines, but only there. Has anyone successfully added an emoji to the body of an LO email?
