Spouse Records
I would love to merge those records and get rid of the soft crediting all together. Does anyone else keep two records for a married couple living in the same household? I have never done this in the past and i find it causes duplicate mailings too.
Thanks in advance,
Sue
We have many cases of records for both spouses. Both have relationship with our org, one or both may be donors. Yes, at times it can be messy. For mailings you'll need to utilize the HoH function to prevent duplications.
If you search the forums you'll find many threads/posts debating this issue. Don't have time to elaborate more right now.0 -
I prefer that they each have their own record. If they are linked as spouses you can easily process mailings to go to only the head of household record. You can also leave soft credits out of reports.0
okay thanks for the input. I guess it's a new learning curve for me.
Historically, we created separate records for each spouse, every single time (no exceptions), but strictly speaking, this is not how RE was intended to be used. It's good to create separate constituent records when each spouse has a separate relationship with the org, but it is not best practices to do this for every single record, as we have done. Essentially, RE was intended to record households unless there is a real reason to have the spouses separate. If that's what you have, then you're fine. If you're like me and have literally thousands (or tens of thousands, to be specific in my case) of spouses who do not need to be set given individual records, then there's reason to work on cleaning things out.
That reason: RE NXT's pricing model is based on number of constituent records. These duplicate household records are a real problem if you've got a lot of them.1 -
I am new to my organizatoin and historically they have created indivdual records for every spouse as well. We have some spouses on Boards, Committees, etc and we want to be able to track this too. My suggestion is to create the attributes in the record and put the spouse's name in the comments as to who is the member of the Committee, etc. I don't like having separate records for the spouses because it gets comfusing especially with gift entry. Thoughts?
I think this statement is the key -- and if you have spouses that serve on your boards and committees, I'd think that's an actual reason to have them separate.
And thinking forward about longer-term maintenance of your records, if you somewhat bury relationship data in comments or notes field, you will often miss these when the relationships change. If you have a separate record created for the spouse, it's very obvious and up-front.
But you do need to understand how RE wants you to handle these relationships - address sharing, soft crediting gifts, head of household processing for mailings, etc.0 -
Our best practice is to always create only one record for spouse/partners. This makes the most sense on many levels including marketing, membership, gift tracking & receipting, event module use, address changes, etc. However, there are times when two records are necessary. Examples of when we break the rule are: 1) If they are both volunteers at our organization so that each person can have their own volunteer record, 2) if they are both prominent members and require their own set of contact information, board member codes, and corporate add/sals, 3) if they were both members before they got married and each one has their own extensive history.
In the case where each spouse/partner has their own record, in addition to linking the reciprocal relationship and marking one as 'Head of Household', we also earmark that record as Primary and the other as Secondary by adding a constituent code on the BIO 2 tab of each record indicating 'linked record primary' and 'linked record secondary'. A pop-up annotate is also added to the secondary record to warn Data Entry that all gifts and membership information should be entered on the primary record. Occasionally, something will get entered on the secondary record in error, but it is very rare and can be easily identified and fixed by running a query on a regular basis.
Having only one record per spouse/partner relationship, if possible, makes for a much cleaner and more manageable database.
I don't agree. I think that it's just as easy to have 2 records. Raiser's Edge is designed to handle this situation quite nicely. You just have to understand how it works.0
I totally agree with your answer. In the case when you have two records, do you create "soft credits" for the secondary records?
thank you for your response...this is very helpful.
Sue0 -
Karen Stuhlfeier:
I don't agree. I think that it's just as easy to have 2 records. Raiser's Edge is designed to handle this situation quite nicely. You just have to understand how it works.It is indeed capable of handling it, but there are intrinsic penalities to doing this for all records. Problems I've faced relate to mailings, marketing, LYBUNT/SYBUNT reporting (what happens when gift entry is inconsistent between the spouses? Do we lose one donor, gain one donor? Lose one donor, reactivate one donor? Both situations are wrong because we have just maintained giving from the household), as well as other metrics relating to donor retention, event analyses, etc.
The system can handle it, but reporting on large swaths of donors becomes very tricky. Thus, these reports are prone to error. This is why I think it's better to create one record per household as the SOP, with exceptions carved out in the ways mentioned here in earlier comments.
Sue Tucker:
SueBy default, our system soft credits the spouse record for every gift entered. I don't know if you can actually change this default behavior or not - I didn't see it anywhere in Config > Business Rules. You can turn it off on a case-by-case basis or with a global change though.
By default our system soft credits the spouse for all gifts.
I really think that everyone has to decide what works best for their organization. I have never had any problems with reporting because of this.0 -
We do not soft-credit the secondary record since both people are together on the primary record and both are included in the primary add/sals, e.g., Mr. and Mrs. John Smith. Only one gift acknowledgement is necessary if it is going to the same household. We don't have our Config set up to autmomatically soft credit relationships and only do so on a case-by-case basis from within the gift, if necessary. The primary record is treated as the main activity record for both people. Depending on the situation, sometimes the secondary record becomes inactive, but we do not want to merge them if each person had a long history with our organization. We have over a quarter million constituent records and the practices we have developed have evolved over many years to what works best for us.0
Sue Tucker:
I am new to my organizatoin and historically they have created indivdual records for every spouse as well. We have some spouses on Boards, Committees, etc and we want to be able to track this too. My suggestion is to create the attributes in the record and put the spouse's name in the comments as to who is the member of the Committee, etc. I don't like having separate records for the spouses because it gets comfusing especially with gift entry. Thoughts?Sue - set up a Business Bule in the Gift Batch to indicate whether the person is HoH or not. That way you know which record you want to record the gift on.
I also preferred to keep 1 record for spousal relationships, with standard exceptions (as mentioned in other responses on this thread).
While I am sure people can manage having two records, I hesitate because if extra care isn't taken, there potentially could issues with reporting. Also, I have looked into Raiser's Edge NXT (that everyone will eventually be converted to) and their pricing is based on number of records. NOT number of RE Users. So if you have 2 records for every spousal relationship, this could quickly make your pricing package go up. Just food for thought.0 -
Lindy - Just curious, what happens if you have a spousal couple but only one makes a gift and specifically states it's only from them and to not include the spouse. Does your setup handle this?0
Depending on the situation, there are two ways that we would deal with this. One would be to send the receipt only to the person who gave the gift and in the reference field note it. In this case we would ask the person first if they are OK with it. However, if this is a couple who is going to be making such requests on a regular basis, then we would create a separate record. Some couple do prefer to have separate giving histories, although it is very rare in our organization.0
What a complicated web spousal relationship are! Been out of office for a bit and this has turned into quite an interesting discussion. Definite different needs/uses from org to org.
I know for many the change to RENXT cost is an issue. My understanding is that cost if based on a range. Having spouse records may or may not change the users range/tier.
I can see arguements for both sides. We do SC spouses and have many cases where spouse has their own record (ex: both have served on our board, have significant relationship with org). If we don't SC there are users who would not see the giving history when they look at the non-HOH record. So with separate records I definitely vote for SCs. Also when death/divorce happens transition is easier, I think.
When spouse is listed under the others record they do not pull in a search unless I've entered their first name/initial. I found this recently when searching for Mary Smith who I needed to mark as deceased. Entering Smith in the search only brought up main records or relationships of records with Smith. I didn't know spouses name but thought she was in RE. To have search pull her as a relationship I needed to enter M/Mary in first name field. Without the first name field only spouse "Bill Smith" is listed without "Mary Smith" in parenthesis with it. Seems strange.
Somehow knowing the spouse wrote the check for the pledge made by the other person, still indicates there is a degree of support from both spouses for our org. While I'm aware of support my husband gives to orgs, there are several that I have no relationship with and if he quit supporting I would be unlikely to support. But, there are others if he quit supporting I would jump right in and send them a donation. As a community org, it's nice to know we have a degree of support from both.
As my dad would say, "another country heard from..."
It is very interesting how everyone handles their own database. Thank you all for the input. I will take to my next meeting and create a workable enviroment for us using all your wonderful ideas.0
JoAnn Strommen:
I know a lot of folks have concern over RE NXT and it being based on the number of records. But from what I understand thus far, the pricing bands are pretty broad, so a couple/few thousand records are not going to change your price point. I have also seen, somewhere - cannot remember if it was here or the FB RE Support Group -- a whole long discussion on this topic of number of records and pricing in RE NXT concerns. Bill Connors will be coming out with a white paper soon on the whole topic regarding number of records and RE NXT and the concerns and pros/cons of deleting records.
Here's a new thought, for anyone interested in doing some cleaning.
I did some research into my database and found that I have about 23k records who are spouses with no giving history (meaning all of the giving history is on the other spouse's record). My plan is to migrate all of these records into relationship records and removing the constituent record related to them.
Here's the basic query I'm using to locate these people:- Spouse Constituent ID <NOT BLANK>
- AND Total number of gifts = 0 (didn't add any criteria to this summary info piece)
- AND Total individual relationships = 1 (avoiding anyone with more complicated relationship trees - I can work on cleaning them up manually later)
- AND Total organization relationships = 0 (same reason as above)
1.) Painstakingly ensure that any other information that exists on these records (appeals, attributes, etc.) is merged into the "head of household" spouse. There really aren't that many records like this, and it's easy enough to query for them (e.g., "assigned appeal <NOT BLANK>")
2.) Once that cleaning is done, I will export all of their biographic information and their spouse's constituent ID number. Basically, anything that lives on Bio 1 and thusly can live in a relationship record will get exported into a .csv file.
3.) Globally delete all of those records.
4.) Add columns to my .csv that define the relationship and reciprocal relationship.
5.) Using the spouse constituent ID I exported, I'll import all of this info as new relationship records on the remaining spouse's record. NOTE: Once this information is in, the existing spouse's addressee/salutation should be just as it was before deleting the spouse constituent records.
So, bam, suddenly I've shifted my organization down an entire pay tier. Right now, we're only a few hundred constituents away from 200k. After this, we'll be closer to 175k. That's a savings of several thousand dollars per year for us.
DISCLAIMER: If you find that you don't have enough spouses to actually impact your NXT payment amount, then this might be too risky to attempt. Also, make sure you have access to a recent backup of your database before attempting any of this. And for the love of god, if you're not really, really confident in your query and import skills, don't try this. It's easy to do lots of damage when dealing with so much data.0 -
Ryan - I'll just also mention that if the spouse has their own email address and you email through NetCommunity, they need their own record?
Wow, is that true? I'd be a little surprised by that, but I have 0 familiarity with NetCommunity. We do our emailing through Sphere (switching soon to Luminate).0
We use the Event Module so we do have two separate records for spouses if either of them attend an event. I do not believe there is a way to register them for an event without them having their own record, unless their name is just added in the Event Module and not linked.0
Gina Gerhard:
We had a pretty standard one record policy. But when we began using NetCommunity we started adding the spouses more liberally because they wanted to receive emails.
EVENTS! We also started making more spouses into consitiituents because of the event module. You can't link to nonconsituent records.
For what it's worth... I also adding a little mailing attribute called "Do not mail - spouse receives invitations" which I just use in my defaults of who to exclude from mailings for those cases where each spouse has a file. Some of our spouses have clearly said they each want to receive letters or invites or whatever, which is why we do it that way. Works for us.0
Gina Gerhard:
Yes, we have separate records for all married couples in our database. We had cards printed for each member of our Sports & Fitness area. Each had to have their own record, as we knew. (My company did not spend enough time or money on training to really educate the staff on how to use RE. So this is what we had to do to get the system to work for us.) I handle the fundraising side and in our world, we want each person to give their own gift, not a family gift. Therefore, we still use separate records and separate gifts for each person. This does make it complicated when adding relationships, like kids.0
We used to have separate constit records for spouses (in our previous database, Advance). When we decided to convert to TRE, our newish Exec Dir of Advancement Services decided to take that opportunity to make “unnecessary” spouse records non-constituent relationship records (we basically downgraded them during conversion). He felt the staff time involved in maintaining those spousal records was not worth it. There are some exceptions where the spouse still qualifies (e.g., they are an alumnus themselves, or a university employee, or other scenarios) as their own ID'd record, but the majority of them are only created as non-constit relationship records now.
I will say that one of the main justifications given for making this change was that when calculating giving, we would only have to look at the HOH instead of summing giving by both spouses. However, we ended up making exceptions for payroll deduction giving and hard-crediting the spouse for those gifts if it was their PD gift. So in essence, we still have to sum giving for both spouses to be sure we have accurate numbers. I found this to be frustrating, as that was one of the main selling points for doing this.
We also consolidated most of our data onto the HOH (ID'd record). Our fundraisers found this to be difficult in some respects. For example, Notes and Actions were consolidated onto the HOH record, which led to confusion where that Action had not actually occurred with the HOH or that Note was specifically referencing the spouse.
Not suggesting one way or the other - just some things we encountered having done it both ways.
