Add Attributes to Event Page
How do I add additional attributes to an events page? They are part of the Event record, but are not available as option in the Online Express Events page.
First, make sure you have your participant attributes setup in The Raiser's Edge > Configuration > Attributes > Participants
Make sure that if you are using "text" or "yes/no" participant attributes that you check the "Allow Only 1 Per Record" box.
Second, when you go back into Online Express, the participant attributes will show up as an option on Step 2.0 -
I am only getting Participant Attributes that are Data Type - "Table" to populate on the Field Options tab. I have tried to "Allow Only 1 Per Record" with a check and without a check and neither one works.0
