Edit donor submitted info when records are linked
When records are linked, is there a way to edit or reject the changes the donor submitted? (ie, didn't capitalize their name, or used all caps, address isn't in correct format, submitted business e-mail but we want to keep the personal e-mail)
Our donors like to avoid capitalization or spell everything out for their address so I'm doing a lot of clean up. When I need to create a new record or manually link records it's easy to edit or reject changes, but I'm not finding how to do that when records were linked behind the scenes. Thanks!
  • Matthew Garbarino
    Matthew Garbarino Blackbaud Employee
    Tenth Anniversary Facilitator 3 Photogenic
    Hi Nike. I completely understand your frustration here. Transaction processing is an area we would like to improve in the future, but for now here is a workaround for the issue you are describing.
    In the case of records where you search for a link, adjust the "New Value" column when you select a linked record. When you are done with edits, click "Save and close".
    In the case of an auto-matched record that needs updating, you can select the "Find Constituent" button, make any updates to the "New Value" column, select the linked constituent under the "Link Online Donor to a Constituent" section, then click the "Link Constituent" button. A prompt will ask if you would like to use the changed data (yes).
