Having issues logging into www.blackbaud.com? We have answers!
In December 2014, we implemented an important enhancement to www.blackbaud.com that will help us prepare the framework for single sign-on. While our Support resources haven't changed, this does change how you sign into www.blackbaud.com. The updated process will allow you to choose to sign into Blackbaud.com using either your email address or Google account.
While these are exciting changes, we wanted to make sure you could easily navigate this change for our website. Check out the videos below for logging in with an email or Google Account:
How to Update your www.blackbaud.com Account to Login with Email
How to Update your www.blackbaud.com Account to Login with a Google Account
Still have questions? Take a look at some of the FAQs below:
Is my Blackbaud.com login the same as my Blackbaud software or the Blackbaud Hosting Services portal login?
No, your Blackbaud.com account login is specific to our website and gives you access to our online Support resources, such as Case Central, Chat, and our Knowledgebase. For more information about our support resources, visit us here (https://support.blackbaud.com/). If you have questions about accessing Blackbaud Hosting Services or your Blackbaud software, you can find helpful information here (https://www.blackbaud.com/support/loginhelp.aspx).
Can I still login under my original Blackbaud.com account username after the update?
No, you will need to update your account to either use your email or your Google account to log in to the Blackbaud.com website moving forward.
What happens if I want to use a different email and password than what's on my Blackbaud.com account record?
No problem! You'll just be asked to log into your Blackbaud.com account one more time with your old username and password during the process. The email address you use during the update process will be your new email on file with Blackbaud where you receive communications.
If I use my Google account, will this update my existing Blackbaud account information?
Yes, your new email on file will be whatever is linked to your Google account. This is also where you will receive communications from Blackbaud.
What if I want to sign in with my Google account and the associated Google email is different than where I want to receive my communications from Blackbaud?
The email address tied to your updated login will be where you will continue to receive communications from Blackbaud. Therefore, we recommend signing up with an account that matches the desired email address for Blackbaud related communications.
When I update my account, can I use the same password?
When updating your account, you can use the same password as before assuming it meets our updated security password requirements (see next FAQ).
What are the password requirements if I sign up using my email?
Your password must meet the below criteria: 7 characters or more Must have at least (2) criteria: Capital letter Number Special character (!, #, %, etc
