Can only Create new Custom Entities, can't seem to query them via Connect API
I have created a new custom entity, I can use the API to create new entries, but I can't seem to query the custom entities via the API.
The custom Entity is called test. When I create a new one I use the entity name test_obj, and when I query it I use select * from test_obj. But on the query I get the error message:
 Error #208: Invalid object name 'dbo.v_a400149_test_OBJ'. on line 1.
 Any ideas?
  • Foss Tighe:
     Any ideas?
    Not that this helps much, but I can query against our Custom Entities in the same manner with success.
    Two possibilities, I think:
    1. Because CEs are different animal, it's possible they may take a while to propogate (if you just created).
    2. It's a specific customer db error. In that case you'd need to open a ticket/case.
    Can you see the records from Sphere Admin?:
    Contacts > Database Management > Manage Custom Entities >
