Query from excel file?
Chong Zhang:
I recently got a list of names in excel file and need to pull them out from the database. I don't think we have vba module in raiser's edge. Is that possible to build a query out of an excel file. Thank you!Any chance you have constituent IDs or Import IDs with your names?
If you do, this link describes how to enter the info using the "one of" option. http://www.blackbaudknowhow.com/the-raisers-edge/creating-queries-from-excel-files-done-easily.htm?utm_source=feedburner&utm_medium=email&utm_campaign=Feed%3A+BlackbaudknowhowcomForBlackbaudSoftwareUsersTheRaisersEdge+%28The+Raiser%E2%80%99s+Edge+Blog%29
If not, I guess my approach would depend upon how big the list is. Small - I'd probably create a query Constituent Name one of using Tab and F7 to quickly look up and pull in the names. If the list is large, you may be better off exporting your constituents with the ID field and then finding the records with duplicates in the list your were given. Save file with ID field and use the 'one of' option.
That's a couple of possibilities anyway.
JoAnn Strommen:
If you have import id's or constituent id's you can use SmartPaste to create the query in mere seconds.
Chong Zhang:
Thank you guys! I didn't have constituent ids, but I used the 'one of' function with their names. The query runs slowly but it works out.
I recently got a list of names in excel file and need to pull them out from the database. I don't think we have vba module in raiser's edge. Is that possible to build a query out of an excel file. Thank you!0
