Importing as a means of grouping through output query
I am trying to import specific salutation text into existing constituent records. I have the constituent IDs and specific text on an excel sheet and that's all. The specific salutation type already exists in RE, just not on these constituent records. I need salutation Id's and I think a good way to start is to capture all of these constituents in a query. I know there is a way to create an output query by importing constituent ids only. It's sort of a fake-out that is really effective. Can anyone help? Thanks!
Peter Mckay:
I am trying to import specific salutation text into existing constituent records. I have the constituent IDs and specific text on an excel sheet and that's all. The specific salutation type already exists in RE, just not on these constituent records. I need salutation Id's and I think a good way to start is to capture all of these constituents in a query. I know there is a way to create an output query by importing constituent ids only. It's sort of a fake-out that is really effective. Can anyone help? Thanks!I know it's late but my brain's not getting it. You are adding vaious formats of salutation text on a group of records. Not all the same format? But using existing add/sal formats? Or all these all needing to be editable. Trying to figure out need for creating a query by import.
If they are all the same add type why not just do a query of constit ID one of and paste in the list of Constit IDs? Then you can do a global change and add the salutation.
Anyway, couldn't remember how to easily create the output query so I just did a search and found this for how to get output query using import: http://forums.blackbaud.com/forums/p/13029/44427.aspx#44427 . There's a link to other thread too.
Peter Mckay:
If you go to Config, then Addressee/Salutations, you can right click and export the Add/Sal grid to Excel. When you figure out what number the Add/Sal is, it should be straightforward to add it to the records using import.
I am trying to import specific salutation text into existing constituent records. I have the constituent IDs and specific text on an excel sheet and that's all. The specific salutation type already exists in RE, just not on these constituent records. I need salutation Id's and I think a good way to start is to capture all of these constituents in a query. I know there is a way to create an output query by importing constituent ids only. It's sort of a fake-out that is really effective. Can anyone help? Thanks!0
