Query Linked Addresses?
Is it possible to query a spouse address to determine if it is linked? I'm trying to find all spouses who have an address that is not linked to the constituent. The address might be the same or it might not, but either way it is not linked. I would like to isolate the spouses who have addresses that are not linked. Steven
    Steven Koplin:
     Possible solution
    From knowledgebase solution BB90891 is sounds like there's a plug in that can help with this.  Below is a paste of part of the solution.  Don't have any other ideas.
    __________________________
    How to find linked spouse records that do not have a linked address
    Answer
    Note: This plug-in is compatible with The Raiser's Edge 7.50.638 and above. The plug-in reports on all linked spouse records that do not have linked addresses.
  • JoAnn Strommen:
     Possible solution
    Answer
     I've used this plug in and it worked very well. It also helped me get across to our end users why it was so important to link spouses correctly. We had quite the list. [;)]
    laura
  • Laura Caswell:
    laura
    JoAnn - thanks for the suggestion. Laura and JoAnn, I'm actually having trouble running the plug-in and have been working with BB to find a solution. Whenever I run the plug-in I get back an empty Notepad file. I know of at least one record (and there should be more) that I expect to appear in the report. Steven
