How to display original gift amount from adjustment?
Hi there,
I would like to find out adjusted gift to display both original gift amount and current amount after adjustment. I can only find split amount from adjustment criteria but original split amount is not what I am looking for.
Any help would be appreciate!
Amy
Amy Wu:
Hi there,
Amy
Have you looked at Reports > Financial Reports > Adjusted Gift Report?
You can use a query of what records to include or just filter by date and filter criteria. Report contains adjusted amount and original amount. Should give you what you need.
JoAnn Strommen:
Hi JoAnn,
Yes I did and because I want a query of adjustment gifts to display adjusted amount and original gift amount, I created a query from the adjustment report as report does display original gift amount. However, in the query output it seems like only 'split amount' but I am looking for original total amount.
Is there any way to output in query just like in adjustment report?
Amy
Amy Wu:
Hi JoAnn,
Amy
The query output screen is not a report. To try to get it to behave like one is a) difficult and b) likely to cause issues.
Have you tried using Export and putting the query into "include"
