Query on Unused Addressee and Salutations
Is it possible to build a query to find out which addressee and salutation types have never been assigned to a constituent record in our database? We're trying to clean up that field before our capital campaign starts next year, and I'm not quite sure where to start on that one.
  • Maria Strong:
    The fastest (and easiest) way is not to run a query, but to attempt to delete the addressee/salutation code. If it is in use anywhere in your database, you will not be able to delete it. Of course, it is tricky to run a query to see which records have a particular addressee/salutation code so you can change them in order to delete an extraneous addressee/salutation, but it can be done.
    Carol Theis:
    As Carol said, trying to delete the add/sal type will show you if it's in use, that's assuming you want the format deleted.  To find where the add/sal is in use you need a query that looks for that add/sal in constituent, individual relationships of all kinds including contacts etc. Have to be thinking of everywhere an add/sal can be entered.
    I will say, I don't use all the add/sal available in RE.  I have the formats I use renamed/coded as the top of the list.  As I'm pretty much set in what we use now, I should go in and delete the unused ones - will put it on 'to do' list :)
