Creating a Co-Captain
We have a team formed by a bigger company and they would like to have two captains.  Is there anyway to enable the TeamRaiser so teams can have more than one captain?
  • Kent Gilliam
    Hi Elizabeth,
    Absolutely. On step 4 #4 you can choose how many captains a team can have.
    Hope you're doing well!
    Kent
  • Kent Gilliam:
    Hi Elizabeth,
    Kent
    Kent,
    Thanks for the response! Things are going pretty well.  I'm bummed I can't attend BBCon, since once again it's the same time as our Walk.
    So my step 4 #4 is about assigning passwords to teams.  I did create a new TeamRaiser this year because I wanted to use the responsive deisgn. Could that have something to do with it?
    I've attached a screen shot of my step four options.
    Elizabeth
  • Kent Gilliam
    Elizabeth Hilpipre:
    Kent,
    Elizabeth
    Let me check something. It might be an SDP that you need to turn on. Be right back.
  • Kent Gilliam
    Kent Gilliam:
    Ok... So there is a site option for this called F2F_MULTIPLE_CAPTAINS_ENABLED. I went ahead and went in and changed this for you and checked your current event and it's now in there as an option. One thing you might check though, I don't know if this can be applied to teams that have already been created. Hopefully it can be applied.
    Bummer you can't make it to BBCon. I'm getting to present again this year. BTW... I'm planning to do a lot more vertical stuff in the Community in 2014 so that means I'm going to get all you animal welfare groups more connected. Hopefully you'll get some value out of connecting with other AW groups in here.
    Great to hear from you as always!!!
    Kent
  • Kent Gilliam:
    Kent
    Hi Kent! I am having the same issue. i would like to offer others the possibly of being a co-captain of an exisiting team. I have the same screen as Elizabeth initially had. Can you edit my teamraiser as well for 2013 Join The Voices? Thank you
  • Kent Gilliam
    Ashley Emrani:
    Hi Ashley,
    You're all set. Again though, I don't have a way to test if this can apply to teams that have already been created or only to future teams that are created. Can you check and confirm if this is possible or not?
    Kent
  • Kent Gilliam:
    Hi Ashley,
    Kent
    Yes, it applies to current teams! Thanks!!
