First time givers across all TeamRaisers
I need to identify all first time donors across all TeamRaisers noting from which TeamRaiser they originated.
I'm wondering if the easiet way to do this is to run a transaction report for a specific time frame and sort out all first time donors? Or does anyone do this differently?
  • Kent Gilliam
    Ancient Membership 2500 Comments 100 Likes Name Dropper
    If your forms/campaigns are clearly labled for each event then you can run a donation by transaction report on just those campaigns/forms and there is a column for "first time donor" that will have "yes" in it if they are a first-time donor.
    Hope this helps!
    Kent
  • Kent Gilliam:
    Hope this helps!
    Kent
    Thank you!
  • Kent Gilliam
    Kerrie Goughnour:
    Thank you!
    And I forgot to add... On step 6 of the report setup you can choose only to show first-time gifts. You have granular options to filter first-time gifts by new online records or first-time gifts by existing constituents:
    Donor Status Types: Select the donor status types for this report. First donation from new constituentFirst donation from existing constituentDonations from previous donors
    This will remove all of that stuff you don't want.
    Hope this is even better!
    Kent
