Social Sharing options
Some of our Teamraiser users have requested the functionality when after someone makes a donation they would like to share on social networks that they recently made a donation to help an event. Additionally, it came up in discussion that once someone creates their fundraising page in the Participant Center, they would like a way to share it with their friends on social networks (other than just copying and pasting the URL to their participant page).
Is there some sort of widget or functionality to do this type of sharing within the registration process or after the step of setting up a personal/team fundraising page? (Otherwise, we use the AddThis widget on some pages now so we thought of embedding that somewhere into our pagewrapper.)
HI Christina,
you can use the facebook sharer snippet
https://developers.facebook.com/docs/plugins/share/
We embed an image button within a modal pop up that will pop right on the initial load of the confirmation / thank you page. The link for that image button is just a simple html <a> tag where the value of the href would contain that exact simple call to fb sharer.php
https://www.facebook.com/sharer/sharer.php?u=YOURPAGEURL
Note: Make sure to replace YOURPAGEURL with the actual page accordingly -- you can employ the Convio S tag to dynamically gives back the current URL of the page that you are currently on.In addition to that we also use 3rd party widget called shareThis
http://www.sharethis.com/#sthash.04qHNEER.dpbs
that allows user or anyone to share the page that they are currently at not only to facebook but to various other social sites (e.g. linkedin, pinterest, emails)
Daniel Hartanto:
HI Christina,
Hi Daniel,
Would you mind sharing a screenshot of what yours looks like? I'm having issues picturing it on the donation or registration layout just by the developer links your provided. Do you have some wording to instruct them of what the widgets do in addition to the developer code?
Christina Relacion:
Hi Daniel,
Hi Christina,
What a coincidence looking at our posting that's almost exactly a year ago
Sure thing, attached is the share to twitter and facebook that we have embedded within the "Thank you" confirmation page of the donation form. In this scenario, I have them linked back to the donation form so that others could also visit the donation form and make donation to the cause.
Also, since the last posting as time flies and we are all have been evolving in a way on our approaches -- just wanted to share that I have also been using this site to help build the content for that social sharing. This would likely be helpful for your purpose. There you'll specify what link to share, heading of your post, additional message you want to put (post copy) and image to be used for the share.
Once you populated those fields, click the button that will generate the code, then copy paste the code onto the Convio WYSIWYG editor as value for the "href" link -- and in this specific example I am just simply using an image button (which is actually image wrap around the HTML a tag) as well as regular text based link.
Thus here's the link to the code / content generator http://watershedshare.com/
Hope that helps. Let us know.
regards,
Daniel
ADD ON: Added second screengrab to show how that share content looks on Facebook
Daniel Hartanto:
Hi Christina,
regards,
Daniel
Thanks so much for sharing!
Christina Relacion:
You are always welcome Christina !
