Social Media links not working
Hi, In our TeamRaiser we've got the Facebook and Twitter links on the home page of the participant centre, but when you click on either of them and then click "share" an error message comes up "Failed - Invalid API key".  This is on a pop-up that is served from Gigya.  Do I need to update a setting somewhere to get this working?
Andrew
  • Kent Gilliam
    Ancient Membership 2500 Comments 100 Likes Name Dropper
    Andrew,
    Have you setup all of your API keys and secret keys? You do that under Cons360 - Social Media - Social Sharing and then click the link in the left-column to record your social network application keys.
    Kent
  • Kent Gilliam:
    Andrew,
    Kent
    Yes, the keys are setup for Facebook and Twitter in that spot and in Gigya.  Any other ideas?
  • Kent Gilliam
    Andrew MacKay:
    Unfortunately I don't have access to dig into this on your site. It sounds like its something our Support will need to contact Gigya support about. Have you opened a case? If not, I can escalate this thread to a case for you so you don't have to re-type everything. Let me know if you'd like me to do that.
    Kent
  • Kent Gilliam
    Kent Gilliam:
    Kent
    Can you post which event it is and if your site is already live?
  • Kent Gilliam:
    That would be great if you could create a ticket Kent.  The event is "W4W - 2014" and the Teamraiser has been published but the event isn't being promoted yet.  http://donate.cwf-fcf.org/site/TR?fr_id=1080&pg=entry
    Thanks.
  • Kent Gilliam
    Andrew,
    Your post requires a little more attention than we can provide in the community so I have escalated it to a Client Services case. If you are one of the contacts at your organization with access to Client Services (support) then you will receive email notifications from the person assigned to help you. If you do not have access to the support portal (the link above doesn't send you to the support portal), please let me know so I can note this in the case.
    Your case number is: 00540799
    Please use the support portal to communicate any additional information with the client services team member assisting you with your case.
    Thank you!
  • Kent Gilliam:
    Andrew,
    Thank you!
    Thanks Kent - I see the new case there
