Top 10 teams listed instead of top 5
We have two divisions for teams for our event (Individual and Corporate teams). Right now, it only shows the top 5 teams per division. I've tried changing on the Greeting page to show top 10 teams, but I don't know which box to update. We would like the thermometer to show and underneath have the top 10 teams per division instead of top 5 per division.
Page is: http://asn.convio.net
Robyn,
Are you using the default greeting page elements or are you using S-tags to place and control your scrolls?
Kent
Kent Gilliam:
Robyn,
Kent
I'm using the default elements. I can't tell by looking at them what is and isn't selected from the elements. But that is what we are using.
If I need to look at the S-tags, I need help to find those. I don't know what they are.
Robyn
Robyn Roberts:
Robyn
S-tags can be used in a full html TeamRaiser homepage that doesn't use the default progress meter and honor rolls. It gives you a lot more creative design ability. You would use the S36 tag to render the different scrolls and control what shows up and how many in each. Here's the main link to the S-tag info: https://secure2.convio.net/customer/luminate_online/v12/s-tags/S-Tags.htm. You can click the link in the left-column to expand the categories and search the TeamRaiser s-tags.
S-tags are not difficult to use. I think once you learn about them it will open a whole new design opportunity for you. We use s-tags in the TeamRaiser kit we have available too.
Kent
Robyn,
There is a site setting named F2F_TOP_TEAMS_LIMIT, this wil set the upper limit of how many teams are displayed. If you are not able to see this setting, Luminate support can help you change it.
