Heat Map/Click Map
Hi!
I am new to this platform and was wondering how to access a heat map and/or a clickmap overlay such as the following....
http://blog.mailchimp.com/clickmap-email-overlay-reports-in-mailchimp/
Page 14 & 15 of this document:
Your post requires a little more attention than we can provide in the community so I have escalated it to a Client Services case. If you are one of the contacts at your organization with access to Client Services (support) then you will receive email notifications from the person assigned to help you. If you do not have access to the support portal (the link above doesn't send you to the support portal), please let me know so I can note this in the case.
Your case number is: 00512279
Please use the support portal to communicate any additional information with the client services team member assisting you with your case.
Thank you!0 -
I know this is an old thread. But has anyone figured out if this is an option?0
Amanda Coleman:
I know this is an old thread. But has anyone figured out if this is an option?There isn't the same interface as MailChimp but you can use clickthrough reports to see what links are being clicked in your emails. If you have two links that go to the same place (ie. donation form) you can differentiate the two links by adding a different subsource code to each one (&s_src=donationlink1 &s_src=donationlink2).
The examples in the PDF you linked to are from a donation page. Using google analytics you can analyze donation pages with heat maps.0
