Can I add an element to encourage constituents to take action from their profile page?
In GetActive the profile page included a list of what advocacy campaigns were available to take and a way for constituents to log other kinds of interactions with legislators. The same functionality does not exist in Convio but there are a few things you can do to provide some similar functionalities.
How to create a page where constituents can log an interaction with a legislator
- Create a survey
- In the survey, add a few questions that ask the necessary information, e.g.:
- "Who did you talk to" -- Short Text Value (40 characters) question
- "Was this through a phone call or a conversation, ... ?" -- Short Text Value (40 characters) question
- "How did the conversation go?" -- Text Value question
- Set the autoresponder to "Do Not Send this Autoresponder".
- Publish the survey.
- Edit the published survey.
- Change the "Submit Survey Button Label" to something more appropriate like "Log Interaction".
- Set the "Survey Submitted Page" to "ConsProfileUser" (the profile page) so that constituent are directed back to the profile page after logging the interaction.
- Create a single component PageBuilder page that is reusable.
- Select "HTML Component" as the component.
- Click on the gear to insert a component.
- Select "Survey" then "Survey" again.
- Then select your newly created survey.
- Continue through the process to publish the page.
How to create a page that shows alerts that the constituent has not submitted
- Select "Advocacy" then "Alert List"
- For "If the user has already taken action" select "Hide the alert".
- This page will be blank if your constituent has taken every active alert you have. As such, you may want to consider at the bottom of the page including a link that something like "No alerts listed? Go to some other page to do some other action!" where the second sentence is a link for the constituent to take some other action such as donating.
- Consider adding a link back to the constituent profile page at the bottom of this page.
How to create links to both of the above in the ConsProfileUser page
- Create links to both of the above pages with wording that is appropriate, e.g.:
- Need to log an interaction with a legislator?
- Interested in seeing what other Acton Alerts are available?
- Go to "Setup" > "Standard Page Center".
- Find and "Customize" the "Constituent Profile (User Update)" page.
- Go through the steps configuring the page to your liking.
- On the fourth step, "Customize Page Footer", click on the gear to insert a component.
Select "Content", "Reusable Page", and then the page you just created, and then "Insert".
- Click on "Finish".
Relevant Links
