Engagement Factors One vs Many
Hello Everybody!
I'm getting ready to set up engagement factors for my organization. I'm wondering what makes more sense. Please weigh in if you feel so inclined.
Does it make more sense to set every interaction at one point (one interaction per engagement factor slot) and then query together as needed? Or, does it make more sense to weight the various factors differently (email received = 1 ... opened = 2 ... clicked = 3, etc.) and combine them on an engagement factor slot?
Please help!
Please help!
Hi Katie,
It is a good practice to have 1 interaction per task/engagement factor and then to run any queries you need to combine factors. So you might have one engagement factor for email opens in 90 days and a second for email opens in 180 days. And then an engagement factor for survey response in 90 days and a second for 180 days. Then you could query for email open in 90 days OR survey response in 90 days for your query of engaged constituents.
Cheers,
Erik5 -
Thank you, Erik!0
Hi Katie -
We have the following Engagement Factors set up in Luminate Online currently. We then run queries and have created groups using these factors to use as suppression or inclusion groups into our communications.
Email - Clickthrough Engagement - Email - Clickthrough (Engagement Factor 8). Has opened and clicked through an email within the last 180 days
Email Opened - 180 days - Email Opened - 180 days. Uses engagement factor 5
Email Opened - 365 days - Constituent has opened an email in one of the last 365 days. Uses Engagement Factor 6
Email Opened - 60 days - Email opened within the last 60 days. Uses engagement Factor 4
Email Received - Opened Engagement - Email Received Engagement. If the email is opened, the constituent received 1 interaction point per email. Uses engagement factor 1
Website Engagement Task - Website engagement task based on Login, Donations and Survey Submission. Uses engagement factor 2
Tammi Burkhardt, MS
Assistant Director of Business Intelligence
OHSU & DOERNBECHER FOUNDATIONS
1121 SW Salmon Street, Suite 100
Portland, OR 97205
PH 503.412.6369 / EMAIL burkhata@ohsu.edu
