Single Sign on for Zoom?
Hello! Has anyone implemented a single sign on with Zoom so that users can log in with their LO info? We want to eliminate duplicates and ask less questions on registration.
When we asked Zoom they said they required a SAML IDP for SSO but I'm curious if anyone has found a way to make this work.
Thank you!
Thank you!
Hey there, Bianca Bickford
These links may or may not be helpful, but I thought I would share our documentation for APIs so that if you have a 3rd party developer, they can help you in setting something up as a single sign on (SSO) that integrates with Luminate Online.-
- Rest API: https://developer.blackbaud.com/lo-api/
- Other API Methods: http://open.convio.com
- API Examples: https://github.com/noahcooper/luminateExtend/tree/master/examples/bootstrap/
- Blackbaud Partner Marketplace: https://www.blackbaud.com/partners/find-partners
- There is also another thread here on the Community discussing API101 in case you need to check that out as well: https://community.blackbaud.com/forums/viewtopic/1/51701
Also, please note that there are two types of Luminate API calls, client side & server side. If you are using server side API calls, those will require an API admin account. To do that, go to Setup > Site Options > Open API Configuration tab and you should be able to set up any admin user/pass credentials you need there.
I hope this helps you accomplish what you're looking to do with Zoom.
Thanks and have a great day.0 -
