Tracking Citizenship
I am wondering how others track citizenship? In RE there is a birthplace, and ethnicity, but I don't see a place to do citizenship.
Thanks
Sherry
  • Austen Brown
    Ninth Anniversary 2,500 Likes 1000 Comments Photogenic
    Hi Sherry Aldrich‍ - We do not track this Citizenship.  However, I would recommend that you add a constituent attribute to track this; make a table field instead of a text field.
  • Hi - another option is to use a field (like religion) that you might not otherwise be using. We did this at the tribal college where I used to work, changing Religion to Tribal Affiliation. It backfired a little because of the difference between official tribal affiliation (enrolled member of the X Tribe) as opposed to how the person wished to be recognized (Hopi/Santa Clara/Choctaw - whatever combo). Before I left there, we were planning on taking over Ethnicity (which we also ignored) and making it the official tribal affiliation, leaving the Religion field to be the tribal "recognition" name.
    The point of that story in your case is to encourage you to use fields that are unused. We did the same with another field (trying to remember the name...) - it became the name of the "pass-through" (like Schwab Charitable, Fidelity, United Way, etc) for DAFs or payroll deductions. We could then insert it into letters or wherever it was needed. I used a LOT of Attributes, but something so "connected" to the constituent as citizenship seems to need a permanent home. Just think it through really carefully and make sure you've considered all the ramifications and to what future uses you might put that information.
    Gracie Schild
    Bluebird Business Services
    Santa Fe, NM
  • Gracie Schild , is there a way to change the label in RE to be citizenship? or would we just need to know that religion = citizenship?
    Thanks
    Sherry
  • Austen Brown
    Sherry Aldrich‍ - You can change any field name by going to Config > Fields and replacing the entry under Display As.  To change the "Religion" field, look under Constituent (near the bottom); verify that the box under Hidden is unchecked.
  • Thank you all for your help, this will at least get us started. I noticed this field is not available in NXT .
  • roger berg
    roger berg Community All-Star
    Tenth Anniversary 100 Likes 100 Comments Photogenic
    Yep - the irritating, "not available in NXT" issue... We use the Religion field on Bio2 but it does NOT exist in NXT so I had to create a Religion attribute and do a bunch of Global adds to come up with a work-around for NXT.
    Moral of the story is, it's great to re-purpose unused RE fields, but if they don't exist in NXT you're going to have to create an attribute (Custom Field in NXT) anyway...
  • roger berg  'Not in NXT' is frustrating but I'm sure it will catch up eventually . Instead of making duplicate fields (for example, religion/citizenship and also an attribute), if i need a list based off from a non available field in nxt, I'll create a static query and use that for the base of my lists for now. I don't want to set myself up for heavy clean up later. Also if my users are updating records, i don't want them to have to update in 2 places, the data integrity will go down quickly.
    I agree there are many benefits in re-purposing fields we are sure we wont' need in the future.
    Most of what i still do for reporting is still in the database view using reports / exports. The database is up to date and all the fields are available. I spend most of my day as admin in the database.  For now I guess I just try to find the happy medium between the 2 systems.
